Clear old Entries from Netsight
Sandeep_Sriniva
New Contributor II
We had enabled Guest SSID to be seen on Netsight however we have removed the Guest SSID but we still see the old entries in Netsight.
How do we clear all these old entries, tried to delete it manually but there are 85 pages of entries around 3500 End systems
3 REPLIES 3
Zdeněk_Pala
If you run Nac Manager (legacy java application) then you can delete them quite easily as all of them will be on the same list.
There is also setting for how long should the inactive endsystem be in the database. You can define when will the endsystem table cleanup happen.
03aca2d0065b4115a4932dd3492c14af_RackMultipart20170110-106252-uw4exh-retention_inline.png
I am sure the setting is also available in OneView.
Regards Zdeněk Pala
Thanks a lot I have set it to 3 days and now I dont see old records.
Ronald_Dvorak
Honored Contributor
Do you mean end-systems in ExtremeControl (NAC) ?
Could you post a screenshot or in which view you'd see all this clients.
