‎06-03-2022 02:47 PM
I dont know if this is the proper location to submit feature request or not, but I have a request that would help me tremendously.
I can get most of the information I need from the Interface Summary page in XMC on about my switches...everything except the VLAN information for each port. This does not appear to be a select-able column to add in this view and I have to open the Device View page to get this information. This is also the same for the interface neighbors information and a few others that I find having to click back and forth trying to compare information.
It seems like these two views could easily be combined into a single view or have the VLAN, Nieghbors, PVID, Roles, etc... columns from the Device View page also be select-able on the Interface Summary page.
Solved! Go to Solution.
‎06-04-2022 12:42 PM
For feature requests I would ask that you create a case, that would be the best way to get a feature request submitted.
Thanks
-Ryan
Thanks
-Ryan
