Compatibility between WS-C25 and Extreme Networks AP3705 Wireless Access Point
Fima18
Hi, In my network I have an Enterasys WC-25 controller with many Enterasys WS-AP3705i access point. Now I have to upgrade the system and I have find out the model in the title. Can I be sure that the controller can correctly rules the APs or can I have some problems?
Thanks a lot
1 ACCEPTED SOLUTION
StephanH
Valued Contributor III
Hello Fema18,
the last version supporting C25 Controller is software version 10.41.12.0006.
This version supports your WS-AP3705I, too.
Official end of  SW support  was Dec 31, 2018
Best regards
Stephan
Regards Stephan
3 REPLIES 3
Fima18
Thank you Stephan!
StephanH
Hello Fema18,
Best regards
Stephan
Regards Stephan
Que tal
tengo una controladora c20 , quisiera saber si puedo conectar ahi APS que tenia en una controladora c25 el modelo del AP es WS-AP3715I ,veo que es error del firmware pero no se si la c20 se pueda actualizar a la versión que soporte los ap que tengo
 Serian tan amables de ayudarme
Saludos
