Benefit of Stacking instead of LAG?
What other benefits are there stacking instead of LAG? Suppose I have two X620 switches which one is best for using best configuration (LAG or Stack)?
Hello, We use netsight 7.1 console to do basic traps and syslog. Is it possible, that netsight could send me an email alert if a problem was seen on an *uplink* port to a stack. I don't want to have to manually run a report, I'd like to have an em...
I want to access mySQL database from external application, is this possible to access it by Excel or power BI
I would like to create an alarm in NetSight to monitor for future PoE failures which create these log messages. bcmPseReceiveMessageString: timed out Is there a trap I can turn on?
One Management release later and still the question is if we can create config templates for XOS devices like we used to be able for EOS devices.The documentation is referring to non-existant content. So in theory we should be able to deploy a templa...
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
