convert or upgrade small to medium appliance NAC / XMC / Anlaytics
10-31-2018 06:47 AM
Hello Comunity,
we made a POC last year with 8.0.5.18 Netsight / Purview / NAC on a customer location...
Now .. "we will buy ist . it works great" ..
"please convert it to medium size because we need analytics "
but no "New install" because we did a lot of integration ...
How can i upgrade or convert a small appliance to a medium appliance ?
Should i convert it alone or can you combine this with an upgrade to last version ?
6 REPLIES 6
10-31-2018 08:51 AM
that would be perfect ,
but can you or anyone from extreme confirm that only change of ressources und Limits will unlock the possibility to use Analytics ?
is the difference from Small to medium to large/Enterprise only the amount of ressources ?
That would be true if it´s an "elastic appiance" .. i know that with EWC it´s correct but i found never Information about XMC/ NAC /Analytics
10-31-2018 07:33 AM
https://community.extremenetworks.com/extreme/topics/extreme-control-small-medium-upgrade
Try to set the CPU/RAM according to the specs in the datasheet:
https://documentation.extremenetworks.com/netsight/8.1/9035435_InstallationGuide.pdf
change the nsserver.cfg XMS and XMX so java uses the resources
root@netsight:/usr/local/Enterasys_Networks$ cat /usr/local/Enterasys_Networks/NetSight/services/nsserver.cfg
-Xms8g -Xmx12g -XX:+HeapDumpOnOutOfMemoryError -XX:HeapDumpPath=../../nsdump.hprof -XX:MetaspaceSize=128m
