Could this script interrupt SNMP process and cause high CPU utilization?
Ilya_Semenov
Contributor
Hello, everybody!
Every morning I get the email from Netsight:
Netsight Critical Alarm: Device Down
Device: 192.168.251.161 (This is a stack of 5 switches)
Severity: Critical
Message: SNMP Contact Lost: No SNMP reply from device 192.168.251.161 caused by SNMP Error: Timeout [4098], last uptime was 10 Days
Could be it caused by these scripts? Especially the last one?
# Module upm configuration.#
create upm profile blackhole1
set var portb 0
set var portb $TCL(string range ${EVENT.LOG_PARAM_0} 36 39)
disable port $portb
create log entry "Port $portb blocked by UPM"
delete var portb
create upm profile mac_move
set var portb1 0
set var portb2 0
set var mac 0
set var portb1 $EVENT.LOG_PARAM_2
set var portb2 $EVENT.LOG_PARAM_3
set var mac $EVENT.LOG_PARAM_0
disable port $portb1
disable port $portb2
create log entry "Port $portb1 and $portb2 was disabled by UPM sript (mac_move), flapping MAC is $mac "
delete var portb1
delete var portb2
delete var mac
create upm profile tftp-save
enable cli scripting
set var CLI.OUT " "
show switch
set var base_list2 $TCL(split ${CLI.OUT} "\n")
set var baseSystemTime $TCL(clock seconds)
set var systemTime $TCL(clock format $baseSystemTime -format {%d.%m.%Y_%H.%M.%S})
set var systemname $TCL(lindex $base_list2 1)
set var systemname $TCL(string replace $systemname 0 17 {})
delete var "CLI.OUT"
#set var filename "$(systemname)_$(systemTime)"
set var filename "$(systemname)"
delete var systemname
#delete var systemtype
delete var systemTime
delete var baseSystemTime
delete var base_list2
upload config 192.168.251.1 cfg/$(filename).cfg VR-Default
delete var filename
Many thanks in advance,
Ilya
5 REPLIES 5
I got the outputs:
Slot-7 sw-416-1.1 # sh upm timers
UPM Profile Flags Next Execution
Timer Name time
Number of UPM Timers: 0
Flags: e - Profile is enabled, ļ˜› Profile is disabled
o -Timer is non-periodic, p - Timer is periodic
Slot-7 sw-416-1.2 # sh upm history
Exec Event/ Profile Port Status Time Launched
Id Timer/ Log filter
989 Log-Message(cfg_save tftp-save --- Running 2016-10-21 14:04:16
988 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:04:05
987 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:03:52
986 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:03:41
985 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:03:29
984 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:03:17
983 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:03:06
982 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:02:55
981 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:02:43
980 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:02:30
979 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:02:15
978 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:01:59
977 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:01:47
976 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:01:35
975 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:01:23
974 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:01:12
973 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:01:00
972 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:00:49
971 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:00:38
970 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:00:26
969 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:00:14
968 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 14:00:02
967 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:59:51
966 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:59:39
965 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:59:27
964 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:59:16
963 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:59:04
962 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:58:53
961 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:58:42
960 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:58:30
959 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:58:18
958 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:58:07
957 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:57:55
956 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:57:44
955 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:57:32
954 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:57:20
953 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:57:08
952 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:56:57
951 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:56:45
950 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:56:33
949 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:56:21
948 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:56:06
947 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:55:53
946 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:55:41
945 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:55:30
944 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:55:18
943 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:55:07
942 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:54:55
941 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:54:43
940 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:54:32
939 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:54:20
938 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:54:08
937 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:53:56
936 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:53:44
935 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:53:32
934 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:53:20
933 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:53:09
932 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:52:57
931 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:52:45
930 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:52:34
929 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:52:23
928 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:52:11
927 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:51:59
926 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:51:47
925 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:51:36
924 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:51:24
923 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:51:13
922 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:51:01
921 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:50:50
920 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:50:38
919 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:50:26
918 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:50:15
917 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:50:03
916 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:49:52
915 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:49:40
914 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:49:28
913 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:49:16
912 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:49:05
911 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:48:53
910 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:48:42
909 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:48:30
908 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:48:18
907 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:48:07
906 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:47:54
905 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:47:43
904 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:47:31
903 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:47:19
902 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:47:08
901 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:46:56
900 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:46:44
899 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:46:33
898 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:46:21
897 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:46:10
896 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:45:58
895 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:45:47
894 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:45:35
893 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:45:23
892 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:45:11
891 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:45:00
890 Log-Message(cfg_save tftp-save --- Fail 2016-10-21 13:44:48
Number of UPM Events in Queue for execution: 1001
Slot-7 sw-416-1.3 #
Could you please tell me why has it gone to endless cycle?
Ilya
