Custom Flexview returns null values in Netsight web page (but works in console)
‎05-03-2017 02:44 PM
Hello Extreme Friends,
I was fooling around with trying to add some Liebert UPS's to Netsight for monitoring. I did the process of importing the MIB's and adding the devices. But the default view doesn't really show much of anything.
So now I am working on a custom Flexview, which is actually quite easy to do. BUT ...
I can load up my Flexview in the Netsight Console, connect to the device, hit Retrieve, and wallah' it works. Yet when I go into the Netsight webpage, and select to view the same device with the Flexview I created, it returns all null values in the fields (a hyphen in place of the data).
Anyone else with this issue, or have an idea of what I did wrong?
I followed this KB to get the Flexview copied from my PC over to the server. Is there an additional step somewhere?
Here is the Flexview TBL file for the sake of examination ...
UPS_IS-WEBLB
com.ets.nac.tables.TbModel
ReqID
OID::ReqID:::SNMP::ReqID
IP Address
OID::IP Address:::SNMP::IP Address
Instance
OID::Instance:::SNMP::Instance
Description
OID::sysDescr:::SNMP::SNMP;true;15;3;false;false;1;2;0;0;0;0;0
Name
OID::sysName:::SNMP::SNMPW;true;15;4;true;false;1;2;0;0;0;0;0
Location
OID::sysLocation:::SNMP::SNMPW;true;15;5;true;false;1;2;0;0;0;0;0
Contact
OID::sysContact:::SNMP::SNMPW;true;15;6;true;false;1;2;0;0;0;0;0
Manufacturer
OID::upsIdentManufacturer:::SNMP::SNMP;true;15;7;false;false;1;2;0;0;0;0;0
Model
OID::upsIdentModel:::SNMP::SNMP;true;15;8;false;false;1;2;0;0;0;0;0
Software Version
OID::upsIdentUPSSoftwareVersion:::SNMP::SNMP;true;15;9;false;false;1;2;0;0;0;0;0
Agent Software Version
OID::upsIdentAgentSoftwareVersion:::SNMP::SNMP;true;15;10;false;false;1;2;0;0;0;0;0
UPS Name
OID::upsIdentName:::SNMP::SNMPW;true;15;11;true;false;1;2;0;0;0;0;0
Battery Status
OID::upsBatteryStatus:::SNMP::SNMP;true;2;12;false;false;1;2;0;0;0;0;0
Seconds On Battery
OID::upsSecondsOnBattery:::SNMP::SNMP;true;2;13;false;false;1;2;0;0;0;0;0
Estimated Minutes Remaining
OID::upsEstimatedMinutesRemaining:::SNMP::SNMP;true;2;14;false;false;1;2;0;0;0;0;0
Estimated Charge Remaining
OID::upsEstimatedChargeRemaining:::SNMP::SNMP;true;2;15;false;false;1;2;0;0;0;0;0
Battery Voltage
OID::upsBatteryVoltage:::SNMP::SNMP;true;2;16;false;false;1;2;0;0;0;0;0
Battery Current
OID::upsBatteryCurrent:::SNMP::SNMP;true;2;17;false;false;1;2;0;0;0;0;0
BatteryTemperature
OID::upsInputLineBads:::SNMP::SNMP;true;65;18;false;false;1;2;0;0;0;0;0
For use with larger Liebert/Emerson/VertivCo UPS systems with monitoring card IS-WEBLB.
TBLHASH::::TBLHDR::0;0;true;30;None;V.0.3.3.0;0;0;116
10 REPLIES 10
‎05-03-2017 02:49 PM
Hello Daniel, thanks for the help.
I had run the scripts to reset NetSight, but had not done a full fledged reboot. So I rebooted the entire server as well, but it still is not working.
Here are the MIB's as they appear on my client, and on my server ...
The MIB in question is "Upsmate.mib".
