Extreme Management connect documentation
hello, how can i install the Extreme connect API? is there any documentation? thank you in advance.
I found an issue with newest version of XMC - Version 8.2.4.42. Configuration evaluation tool (WEB) does not interpret properly location data from wireless. Below you can see screenshot from legacy java version and web version – difference is in fie...
I´m buidling a Netsight System with different locations. unfortuanally some locations using "wrong" Ip Addresses becaus of historical reasons ... its not possible to change these addresses becaus there are large networks behind them. The Problem is ...
Hi...I created one group of 16 ports and I have started my flex view to show the amount of time the 16 ports are UP. The result is that I see only 11 ports if I use any other original flexview I see all the 16 ports Can any one help me??
Hi folks!!! When I try open GUI to VSP from XMC DEvice tab (View --> Device details --> Launch WebView) it doesn´t open. I capture traffic and see that XMC try to redirect me to http port 80, but my devices are configure in secure option, only all...
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
