Device connection issue - contact not established - snmp
Tomasz_Lubas
New Contributor III
I have problem with NMS add/contact device [B5 switch]. The device is configured, pingable, telnet/ssh work ok from netsight appliance. Also snmpwalk with netsight credential from NMS appliance [cli] works as it should work.
[eg. snmpwalk -v3 -l authPriv -a SHA -x AES -u Very_secret_user -A secret_password -X secret_password 10.70.16.12
iso.3.6.1.2.1.1.1.0 = STRING: "Enterasys Networks, Inc. B5G124-24P2 Rev 06.71.03.0025"]
The device on NMS Console is shown with '?' mark. Refreshing, rediscovering, deleting and adding again doesnt solve problem. From NMS console I can run Device manager [work ok], execute MiB's - works ok, but still there is 'contact not established' status.
bf63dc00ee2d4ca68d64334f1a88b513_RackMultipart20151002-28582-n3k1el-snmp-problem_inline.jpg
Any sugestions ?
[ps. this devices was previousely present at NMS [ok] and disconnected for some time]
Supplement: When I manualy run Tools->Discover with device ip address and snmp creds - device was connected ok and now looks ok.
5 REPLIES 5
Ryan_Yacobucci
Hello Tomasz,
When you initially add a device into NetSight they will show up as a ? until the device is contacted through SNMP. Once contacted NetSight determines what the device type is and gives it the correct icon per the device type. In this case the device type is not known as NetSight was not able to get any information from the device. Are you still having issues with this specific device?
Thanks
-Ryan
Mike_D
Hello Tomasz,
Assuming creds are a match - as per Piotr's suggestion - next up on my own checklist is protocol analysis. A switch side network trace while running management tests would go a long way toward ruling out protocol (and yes credentials) problems.
Regards,
Mike
Piotr_Owczarek
New Contributor III
Maybe the problem is CLI credential on the switch and NMS mismatch?
Tomasz_Lubas
New Contributor III
Hi Ryan, thanks for reply. Device was mapped ok, right profile, credentials and so on. Normally if the device is reached and no SNMP connection is established - then in NMS is orange arrow near device. In my case there was '?' as if not accessible at all:)
