08-16-2024 02:30 AM
I am trying to backup a configuration from a Huawei switch by using SCP. By default, the GitHub repo of Extreme only has the TFTP option for Huawei. I have created a new device family type by creating a script named huawei.scp and adding it to the directory /usr/local/Extreme_Networks/NetSight/appdata/InventoryMgr/properties/devicefiles, which is the default.
I have tried both restarting the VM, as well as the NetSight service, and the new device family type (Huawei - SCP) is not appearing under the Inventory Settings for that particular switch. I am providing a copy as well of the script.
- Use these scripts to manage an Huawei S5720 device
name="Huawei - SCP"
desc="Huawei S5720 SCP Scripts"
protocol=SCP
-----BEGIN SCRIPT "Configuration Upload"-----
save NMS.cfg
y
@receive 8
scp NMS.cfg %SCP_USER%@%TFTP_IP%:%RELATIVE_TARGET_FILE_PATH%
@receive 15
delete flash:/NMS.cfg
y
quit
-----END SCRIPT-----
-----BEGIN SUCCESS "Configuration Upload"-----
Info: Uploaded the file successfully.
-----END SUCCESS-----
Can anyone shed some light on what may be going on?
Thanks for your help,
Solved! Go to Solution.
a month ago
Hello,
The underlying problem is that you have protocol=SCP but you have configure variables for a different transfer method.
Change %TFTP_IP% to %SCP_IP%
Thanks
-Ryan
a month ago
this one works for TFTP: https://github.com/extremenetworks/ExtremeScripting/blob/master/XMC_XIQ-SE/cfg_backup_scripts/Huawei...
Try to modify it... THe issue can be with some hidden character or end of the line...
a month ago
Hello,
Thanks
-Ryan
