‎09-01-2021 05:15 PM
Are there any guides on how to upgrade or migrate Extreme Management Center to the new XIQ-SE?
Solved! Go to Solution.
‎09-03-2021 02:31 PM
Thank you Mark.
I see, we have typo there.
The upgrade to 21.4.10.99 is not tested from 8.5.6. as 8.5.6 was released after the 21.4.10.99.
If the customer is on 8.5.6 and wants upgrade to XIQ-SE then there are two options:
‎09-01-2021 07:45 PM
Hi Byron,
From technical point of view, it is like a upgrade for the XMC.
It is described in the release notes:
From a license point of view you should check that with you local sales representative.
As wel in the release notes:
Mig
