Does WLC V10.41.06 firmware support NAC and Net sight 6.3 version ?
Aman
New Contributor II
We are going to upgrade Our WLC(V2110) from V9 to V10, I have one doubt currently
we are using Netsight 6.3. Does this WLC version v10.41.06 firmware support NAC and net sight 6.3 or not?please help.thanks in advance.
4 REPLIES 4
Darin_Seiler
I can't confirm 10.41.06 but we did successfully run two C5210 wireless controllers on 10.41.01.0082 with Netsight 6.3 and had no issues
Ronald_Dvorak
Honored Contributor
There is a difference between working and supported.
It might work with 6.3 but it's not supported (was also not tested) and that would mean no support for this kind of installation from the GTAC in case of an issue.
Aman
New Contributor II
Do we have to upgrade the net sight also?
