EMC maps - no style / draw wall option
‎11-18-2016 04:34 PM
I'm running EMC 7.0.6.27 with a valid NMS-ADV-U license but don't see the option to draw walls.
The map proberties are set to floorplan, custom and I've selected edit but there is no style option as mentioned in the online help.
I haven't played with the draw wall map function for a while so might be that I'm doing something wrong.
-Ron
-Ron
5 REPLIES 5
‎11-18-2016 04:50 PM
Use the drop down where it says select items. The drawing tools are there.
LOL, you are right, if I select one from the select items list I've the style option available.
Thanks a lot....
Thanks a lot....
Ron, what do you see when you click "Select Items"? You should be able to click "line" or "square" or something. In fact, you should be doing that before Style or Wall shows up, which is odd.
Is this perhaps a browser bug? Could you try using IE/Chrome/Firefox/etc?
Try a different browser. Could be that.
