EMC maps - no style / draw wall option
Ronald_Dvorak
Honored Contributor
I'm running EMC 7.0.6.27 with a valid NMS-ADV-U license but don't see the option to draw walls.
The map proberties are set to floorplan, custom and I've selected edit but there is no style option as mentioned in the online help.
I haven't played with the draw wall map function for a while so might be that I'm doing something wrong.
-Ron
e900be1de3254d7093ea1f8e718858b9_RackMultipart20161118-10406-cxljre-map_draw_wall_inline.png
5 REPLIES 5
There is no draw wall option in select items - as per the online help the style option should be right beside the select item pull down but there is nothing in my case.....
936be3b466d6483cb26b9c2158bad5d9_RackMultipart20161118-74025-13its3z-map_draw_wall_options_inline.png
