EMC Web Gui Slowness
Ian_Broadway
Contributor
Hi All,
We're running EMC version 8.1.2.59.
We're noticing slowness when using the web gui. Browsing device groups etc makes the devices disappear frequently in the menu and you have to refresh the page to get it back. Seems to be the same regardless of which browser we use, chrome and IE
Is this a known bug in this version?
4 REPLIES 4
Ian_Broadway
Contributor
does actually seem ok now. will keep and eye on it.
Ronald_Dvorak
Honored Contributor
Must be brand new, I've cheked yesterday and the software wasn't on the server yet - it's now so let's see how fast I'd load all the files 🙂
Ian_Broadway
Contributor
I check almost daily, hadn't checked today and typical there is now a new release although nothing specific on our issue. Will update and hope for the best.
Ronald_Dvorak
Honored Contributor
You'd check the release notes - 8.1.3 is already on the page....
https://www.extremenetworks.com/support/release-notes/
