Enable ssh2 or telnet on XOS without using the console port
Carsten_Volmer
New Contributor II
Hello, at all!
I have made a mistake by disabling ssh2 and telnet on an X460G2 (fw 22.4.1.4). And now i can't manage the switch per remote. Is there a possibility by enabling ssh2 or telnet on this switch without driving to the system and using the console port?
Thanks for your interesting!
8 REPLIES 8
Dave_Hammers
Is the web interface still working? You could try that.
If you have a python environment on your server, you could try using the jsonrpc_client.py
https://github.com/extremenetworks/EXOS_Apps/tree/master/JSONRPC
Ronald_Dvorak
Honored Contributor
did you save the config > if not could someone onsite just unplug/plug the power cable
Ronald_Dvorak
Honored Contributor
is web still enabled ?
Patrick_Voss
Hello Carsen,
I apologize. I think your only option is to console in to make the configuration change.
