Exporting NAC End System Data
Andre_Brits_Kan
Contributor II
How do I go about exporting the end system information from NAC Manager to excel?
In oneview I can export to a PDF but I would like to export all the data to Excel.
Thx
Andre
14 REPLIES 14
StephanH
Valued Contributor III
Hello all,
The NAC Request Tool can be a workaround for me to export all "End Systems" from NAC/NetSight.
But will be the NAC Request Tool still available if the Java tools are no longer supported?
Regards
Stephan
Regards Stephan
StephanH
Hello Mike,
no, I am afraid not. I know the PDF but my customers use the exported data to create data for different reportings and as import source for other IT Systems. They need a csv for import.
If there is a file in file system or script on the operating system (we use Netsight as Linux appliance) that will be ok for me. I need no GUI.
As I mentioned Webservices are not very handy and if I have to export 35.000 End-Systems via "axis/services/NACWebService/getallEndSystem" is very very slow!
Stephan
Regards Stephan
Mike_Thomas
Got it.
From Extreme Management Center, Control Tab->End System->Tools->Generate PDF
This may meet your requirements.
StephanH
Hello Mike,
thank you for the fast response. But I am looking for an export of the "End-Systems" and not for "End-System Events" descripted in the mentioned GTAC article.
Regards
Stephan
Regards Stephan
Mike_Thomas
