Extreme API login in Netsight
‎09-13-2017 03:10 PM
Upgraded Netsight EMC to 8.0.3 and now in the Console tab, I am seeing Authentication Failures for user "extremeapi" I have no idea where this is coming from? Any clue where this might be configured?
6 REPLIES 6
‎09-13-2017 03:35 PM
Hey Ryan,
I dont run Identity Management on exos switches. I see it disabled on all my summit stacks and I also dont see the username "extremeapi" in OneView Identity Management config.
‎09-13-2017 03:20 PM
Do you have Identity Management enabled on the exos switches?
Might be your switches trying to push XML updates.
Thanks
-Ryan
Thanks
-Ryan
