Extreme Connect API with Mobile Device Management Systems -> Issue caused by iOS 14.0.1
Extreme-LoCo
iOS 14.0.1 automatically enabled the Private MAC Address feature. If members within your organization upgrade to iOS 14.0.1, and enrollment within oneā€™s Mobile Device Management is prerequisite to connection to an SSID, then this feature will break connection to the SSID until it is disabled.
https://support.apple.com/en-us/HT211227
Disable the option.
The iDevice will be attempting to connect to the SSID utilizing a MAC Address that is not imported/whitelisted from your mobile device management.
1 REPLY 1
Zdeněk_Pala
the MDM provides to XMC information about the physical MAC address.
If the wireless device does not use a physical MAC address then such a device is not considered as managed by MDM.
The best option is to disable the Private MAC address for that SSID.
Regards Zdeněk Pala
