Extreme Control License 24 Hour Period Start and Stop
Anonymous
Not applicable
Have been asked a specific question about when the 24 hour period of the NAC counter end-system licensing restarts, for example; my assumption might be it is at Midnight every night, but it could equally be any time or something that is configurable?
Just wondering if anyone knows?
Many thanks in advance.
2 REPLIES 2
Ronald_Dvorak
Honored Contributor
Hi Martin,
here the answer that was given back in 2013 in the Enterasys mailing list....
Is this a question about how the number of end-systems for a 24 hour period, which is used for licensing, is calculated?
If so that logic runs every hour to figure out the max end-systems within the 24 hour period.
The max of those 24 values is used for that day.
The license check that uses the end-system count value is run at the same time as the data cleanup.
That is configurable in options under NAC Manager -> Data Persistence -> Run Data Persistence Check.
-Ron
Anonymous
Not applicable
Nice one Ron, really helpful. Thanks
