Extreme Control Rule and AD
Ian_Broadway
New Contributor III
Hi All,
I am trying to create Extreme Control rule sets for MAC and .1x authentication.
Is there not a way I can add a group condition to query a LDAP/AD Domain group?
I can see there is an option for LDAP user groups.
Also, do Extreme offer some sort of downloadable config for updating DHCP fingerprints.
Its really tedious to have to go in and add lines of code to add custom fingerprints, not to mention having to hunt through a log file to get them in the first place.
One other thing, any ideas/thoughts on being able to add if/or conditions into the same rule?
Thanks
Ian
1 ACCEPTED SOLUTION
Miguel-Angel_RO
Valued Contributor II
Stefan,
With a script from @Zdenek Pala (https://github.com/extremenetworks/ExtremeScripting/blob/master/Netsight/oneview_workflows/combo/Use... you can mix both authentications to ensure that the user authentication is done on a computer from the domain:
"Add MAC to Domain Computers" is executed when the computer authenticates. The MAC address is added to End-System and the timestamp is created (updated). Consequent User authentication can be combined with the condition of the End-System group. "Clear old End-Systems in the group" checks if the timestamp is older than X hours and old End-Systems are deleted from the group.
Mig
47 REPLIES 47
StephanH
Valued Contributor III
Hello Stefan,
here you can see how to configure Windows for  Computer or/and User authentication with EAP. This is the basis for the mentiond KB article from Mig.
https://extremeportal.force.com/ExtrArticleDetail?an=000080814&q=nuc%20802.1x%20ldap%20user%20
Regards
Stephan
Regards Stephan
Stefan_K_
Valued Contributor
Thanks, will test this out! 🙂
PeterK
Contributor III
You need to configure this in the 802.1x supplicant in windows. The default is afaik computer-account. But you can also choose computer and/or computer account. When a user logs in, the identiti switches from computer account to user account.
Stefan_K_
Valued Contributor
Hi guys,
just a short question on this topic. When using 802.1x computer authentication the user coloumn in ExtremeControl is populated with host\computername.domain.tld
Is there any way to additionally check for the user that is logged on the computer? I want to use the client certificate to authenticate and the user to authorise based on the users AD Groups.
BR
Stefan
Miguel-Angel_RO
Ian
There is a way to configure the NAC for host authentication that doesn’t seems obvious but needs to be followed.
You must create an LDAP connection for user authentication and one for computer authentication.
For the computer authentication (almost copy of the user one) you must use “servicePrincipalName” as “user search attribute”  because the computer is in fact doing a “user authentication” with his own credentials.
You’ll have to adapt you AAA authentication rules to send computer authentications (host/*.ldap.domain)to the “computers ldap”
Check this for the config and let me know:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-authorise-Windows-domain-user-compu...
Mig
