Extreme Control small/medium upgrade
Ronald_Dvorak
Honored Contributor
Hi, in the 8.0.3 release notes there is this nice comparison chart...
91ab1c06ef2b49c2b7d12c499153d5f9_RackMultipart20171011-112563-1pv2gth-NAC_differences_inline.png
Beside that I think that the requirements are a little high could I deploy a small engine and later on if I need to auth more end-systems or support for portal just increase the CPU/RAM/HDD or do I need to install the medium .ova from scratch.
Thanks,
Ron
4 REPLIES 4
Adam_Minowski
You can do it by changing CPU and Memory allocation under hypervisor.
In order to have more place you should add additional disk to the machine.
As XMC is using LVM, the additional disk should be automatically added to the XMC appliance, and you should see more free space on systemvg and root filesystem.
Don't forget to also change Xms and XmX values in accordance to document:
https://gtacknowledge.extremenetworks.com/articles/Solution/EMC-memory-settings/?q=netsight+small+to...
Doug
Assuming your license supports it, you can just increase the CPU/RAM/HDD similar to the controller.
Doug Hyde
Sr. Director, Technical Support / Extreme Networks
AntonS
Contributor II
have you tried to increase the cpu/ram?
the wireless controller setup detects the hardware and autmatically sets small/medium/large.
Ronald_Dvorak
Honored Contributor
anyone ?
