SamPirok
ExtremeCloud™ IQ - Site Engine (XIQ-SE) 23.11.12.3 has been released!
You can view the release notes here
The downloadable files can be found on the Extreme Portal, under Products:
23.11.12.3
2 Comments
netjradm
i can't find the firmware support matrix for Version 23.11.x.
https://emc.extremenetworks.com/content/common/releasenotes/extended_firmware_support.htm
Is there no change in regard to Version 23.7.x?
Best regards
Stefan
Robert_Haynes
As I understand things a parallel effort is underway to certify certain platform hardware undergoing SNMP changes which is delaying the posting of the matrix. I am not aware of a timeline when this is expected to be completed.
For now and in absence of any other data I would consider the 23.07 matrix applicable to 23.11 until otherwise posted.
