ExtremeControl 7.0 early release list
‎03-21-2016 06:55 PM
Any release schedule available for ExtremeControl 7.0 early release.
Could you please put me on the early release list I'd like to see/test the OneFabric integration.
Thx,
Ron
Thx,
Ron
56 REPLIES 56
‎04-13-2016 01:31 PM
you should be able to see it in downloads now. You will need to use a new eval key dated in April for it to work.
‎04-11-2016 01:41 PM
Okay, so some may have noticed that a new key will need to be generated for current install users that are not running with an eval only key (which has been generated since April)
Here is a link to the key regeneration process.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-upgrade-a-NetSight-license-for-use-...
‎04-11-2016 05:19 AM
Thanks again Mike.
I've rx a email from Eric about 7.0 ...
"Once the upgrade is complete we’d be interested in feedback specific to the release and may also request some log data pertaining to the upgrade."
Which logs are you interested in and how should we provide it to you.
I've upgraded my lab Netsight, NAC, Purview - it's only a small test installation but if you like to have my log data I'd provide it to you.
-Ron
-Ron
Hi Ron, if there are issues, or a reach out at a certain point, the minimum requirement will be a show support, at least from the Netsight Appliances point of view.
‎04-08-2016 05:27 PM
I think I have added all current requested users. Let us know if we missed you.
The early access release should be seen here,
https://extranet.extremenetworks.com/downloads/Pages/NMS.aspx
You will need to login with your credentials that are assigned to the email address that you are using on the hub. I have used your hub email as a basis.
