Failed Script - Wireless WLAN scheduler
‎12-05-2018 10:01 AM
Hi Community
Has anyone encountered any issues when running the WLAN scheduler script from XMC? I get an error "
*** Error at line - 67 ***
SSH connection problem: cause: java.util.NoSuchElementException: no common elements found". Current version (Still Netsight) is 6.3.0.174 with Server JRE Version: 1.7.0_79. Wireless controller version Software: 10.31.05.0003 on Hyper-V. The script fails at the "ENDIF" statement at the end of the script. The same script completes successfully on Extreme Management Center 8.1.5.22 with Server JRE Server JRE Version: 1.8.0_171 and wireless controller Software: 10.41.07.0014. I'm unable to upgrade now so would like to verify if a solution exists for current versions. Script content below.
Ask your question
Ask your question
0 REPLIES 0
