Flexview AP stats
‎09-30-2016 01:20 PM
I'm trying to create a Flexview that shows the following OID's:
dot11ExtRadioAvgNfCount=1.3.6.1.4.1.4329.15.3.1.4.3.1.31
dot11ExtRadioMaxNfCount=1.3.6.1.4.1.4329.15.3.1.4.3.1.32
dot11ExtRadioAvgChlOccCount=1.3.6.1.4.1.4329.15.3.1.4.3.1.33
dot11ExtRadioMaxChlOccCount=1.3.6.1.4.1.4329.15.3.1.4.3.1.34
These stats return correctly, however I have no way of identifying the AP's "instance".
I tried adding the apName OID to the flexview which returns the names correctly, however it also seems to prevent the stats columns from populating data. Any Tips? Thanks much.
6 REPLIES 6
‎10-05-2016 01:23 PM
Okay. Thanks for checking.
‎10-04-2016 06:34 PM
Hello Joshua,
Let me see if can set something up in our lab and check if there is an OID I can use to map back to that.
