Temperature Threshold in Degrees C
‎09-28-2016 12:51 PM
Hi
I have been told that Netsight 7 now can do the overheat threshold alarm in Celsius or Farenheit. Where is this set, i can't find it.
5 REPLIES 5
‎10-05-2016 11:40 AM
Hello,
That case has been closed pre-maturely. Currently this fix is targeted for 8.0, but this is subject to change.
Thanks
-Ryan
Thanks
-Ryan
‎10-04-2016 05:28 PM
Hi
Case no:01152800
Case no:01152800
‎10-04-2016 03:25 PM
What case number was it opened under? I can check to see what the status is.
Thanks
-Ryan
Thanks
-Ryan
‎10-04-2016 02:01 PM
Hi
I received an email that the fix had been released as I had a open GTAC case for it. I assumed it was fixed in rel 7 of Netsight.
