Force NetSight to use HTTPS
Anonymous
Not applicable
‎12-02-2015 09:38 AM
Hopefully this is an easy one.....
Is there anyway to force the use of HTTPS directly via the NetSight application. As an example when I delete port 8080 from the 'Web Server' options it forces me to put a port number in, or a simple radio button somewhere that disables it?
Many thanks in advance.
14 REPLIES 14
Anonymous
Not applicable
‎03-18-2016 05:07 PM
Just thought I would post the path in either situation 🙂
Windows Server:
NetSight_Install_path (probably Program Files)\Extreme Networks\NetSight\appdata\
Linux Server:
/usr/local/Extreme_Networks/NetSight/appdata/
Windows Server:
Linux Server:
‎03-18-2016 05:04 PM
linux
‎03-18-2016 04:59 PM
It would be on the server. Is your server linux or windows?
‎03-18-2016 04:39 PM
Is that on your machine or on the server? I cannot find an appdata directory on the server and making the change on one machine does not seem to really solve the problem.
Thanks,
Thanks,
Anonymous
Not applicable
‎03-18-2016 04:13 PM
Hi David, the answer is above in editing the NSJBoss file. If you comment out the line given you will no longer be able to connect to NetSight using http. Thanks
