Governance Engine
‎07-28-2017 07:10 AM
are there more informations available.
I'd see the product in the price list and the webpage shows only the datasheet with some marketing yada yada.
Is that only a license for EMC or another VM server ... what do I need to test this and is it available now, is there a trial license.
Thx,
Ron
Thx,
Ron
15 REPLIES 15
‎11-15-2017 12:29 PM
very interesting
as our company needs to fulfill PCI-DSS standards I was intressted in this new feature.
but as it looks it is too early for that
i didn't knew a seperate license is needed!
‎08-04-2017 12:44 PM
Anyone from the EMC team that like to comment on the wrong information in the report ?
‎07-28-2017 10:41 AM
I've run the PCI test on all my devices but I'd like to concentrate on the wireless controller because I've a little bit experience on that one 🙂
My setup is a V2110 pair running 10.31.04 - all APs are on #1 and #2 is my standby.
As they run in an availability pair all settings should be equal.
The result of the PCI test is that #1 passed with 89% and #2 failed with 5%.
Also the number of test failed in the diagram doesn't reflect the number of failed test in the list of tests in both cases.
Here a screenshot of both results with a filter on failed tests....
Let's get into detail....
failed test#1&2 on both EWCs = secure connections (Disable weak ciphers for secure connections)
On both EWCs (in GUI > Controller > Network > Secure Connections > enable Weak Cipers) the checkmark isn't set = disabled
failed test#5 only on EWC#2 = Default AP modes - strong cluster-shared secret
On both EWCs (in GUI > AP > Global > Registration > Secure Cluster > Cluster Shared Secret) the same pw is set - I think it's the default - in my case MvrDqIeb
failed test#5-7 only on EWC#1 = Implement a strong password SNMP admin user
On both EWCs (in GUI > Controller> Network > SNMP > SNMPv3) the same user snmpuser with default pw is set
Summary: Even both controllers of the pair have the same settings I get different results on the individual test and one controller passes the overall score with 89% and the second fails the score with 5%.
-Ron
-Ron
‎07-28-2017 10:08 AM
Thanks I'll give it a try.
