GraphiQL doesn't give a correct list of VLANs ID
Nealo
Hello,
I’ve been trying to get a list of the VLANs on a VSP device.
The device is a VSP-8404 with 6.1.6.0 firmware, and the XMC version is 8.2.4.55.
I know of two ways to get them.
The first one would be to send a CLI command with emc_cli, and get the output, then filter it to get a list.
cli_output = emc_cli.send("show vlan basic").getOutput().encode('ascii', 'ignore')
The second one is using emc_nbi and sending a query to get the VLANs ID
var_query = '''query{network{device(ip: "DeviceIP"){deviceData{vlans{vid}}}}}'''var_result = emc_nbi.query(var_query)vlans_id = var_result['network']['device']['deviceData']['vlans']
But, I noticed that using NBI doesn’t give me the same result as using CLI.
With CLI, I get this list :  1, 2, 49, 170, 180, 190, 4049, 4051, 4052
With NBI, I get this list : 1, 2, 49, 170, 180, 666, 4049
The NBI is not correct, as I don’t get the 190, 4051 and 4052, and it adds the 666.
I don’t understand why this difference is present. Is there something I’m doing wrong ?
Thanks a lot for the help
1 ACCEPTED SOLUTION
rbrt
Contributor
Hey everyone,
I had the same problem with the NBI and, together with GTAC, found out that refreshing the device with a mutation and querying the right context within the NBI solves it - at least for EXOS and EOS. Try this (replace the IP with the management IP of the switch in question):
mutation {
network {
rediscoverDevices(input: {devices: [{ipAddress: "10.0.0.1"}]}) {
status
message
After firing this mutation, wait for 15 minutes (or check the Operations view) and try the following GraphiQL query (again, replace the IP).
query {
network {
deviceVlans(ip: "10.0.0.1") {
name
vid
primaryIp
netmask
ipForward
See https://link.medium.com/m5yqUU15y0 for an in-depth story on that topic.
9 REPLIES 9
Nealo
Thanks a lot for all those information !
rbrt
Contributor
There is a lengthy, open GTAC case regarding API behaviour, which I condensed in the article I shared above. To summarize it for the context question: The API is still in development and deviceVlans is the right context to use for now. Out of the case, from Engineering:
In a nutshell, the query is for deviceData which internally is cached mainly for provisioning/ZTP and should not technically be used for reading device info
As far as I know there is a CR to remove the deviceData/vlans context from the GraphQL API, targeted for XMC 8.4 or 8.5. So this issue will be “solved” soon.
Nealo
I have a question about that request.
The output is different if I use
network {deviceVlans {vid or
network {device {deviceData {vlans {vid
Shouldn’t both give the same result ?
Thanks
rbrt
Contributor
The mutation above just triggers a refresh device within XMC, so no changes are done to either the device or XMC.
