How call OneFabric Connect WebServices function from a php script?
‎07-19-2017 11:55 AM
HI, I'm trying to made a php script (I'm not a php programmer), that execute a web services that in my example is:
https://root:password@192.168.30.34:8443/axis/services/NACWebService/addIPToEndSystemGroup?endSystem...
If I execute this web services from a web browser, it works correctly.
Then I want to execute the same command with a php script.
I've follow the examples that are in the OneFabric Connect WebServices pdf document, and my php code is the following:
$login = 'root';
$password = 'password';
try {
$client = new SoapClient(
'https://' . urlencode($login) . ':' . urlencode($password) . '@192.168.30.34:8443/axis/services/NACWebService?wsdl',
array(
'login' => $login,
'password' => $password,
'authentication' => SOAP_AUTHENTICATION_DIGEST
$response = $client->addIPToEndSystemGroup(array("endSystemGroup" => "Distributed_IPS","ipAddress" => "192.168.10.78","description" => "ck infected","reauthenticate" => true,"removeFromOtherGroups" => true));
print_r($response);
} catch (Exception $e) {
printf("Error:sendSms: %s\n",$e->__toString());
print($client->__getLastResponse());
return false;
The problem is that this script end with an error that is the following:
root@extrememanagement.demo.com:~/scripts$ php test3.php
Error:sendSms: SoapFault exception: [Client] looks like we got no XML document in /root/scripts/test3.php:16
Stack trace:
#0 /root/scripts/test3.php(16): SoapClient->__call('addIPToEndSyste...', Array)
#1 /root/scripts/test3.php(16): SoapClient->addIPToEndSystemGroup(Array)
#2 {main}
I've made a search on google for this error, but seams that must be correct changing same setting on the server side....
Is there someone that know how to execute this web services from the php script?
Thanks
$login = 'root';
try {
array(
'login' => $login,
print_r($response);
return false;
Stack trace:
#2 {main}
Thanks
5 REPLIES 5
‎07-20-2017 11:19 AM
Hi, below the output of the php script if I enable the trace option in the SoapClient:
SoapFault exception: [Client] looks like we got no XML document in /root/scripts/Distributed_IPS.php:37
Stack trace:
#0 /root/scripts/Distributed_IPS.php(37): SoapClient->__call('addIPToEndSyste...', Array)
#1 /root/scripts/Distributed_IPS.php(37): SoapClient->addIPToEndSystemGroup(Array)
#2 {main}
Seems that the server return the html page for the login where asks for username and password....
Stack trace:
#2 {main}
code:
POST /services/NACWebService HTTP/1.1
Host: 192.168.30.34:8443
Connection: Keep-Alive
User-Agent: PHP-SOAP/5.5.9-1ubuntu4.21
Content-Type: text/xml; charset=utf-8
SOAPAction: "urn:addIPToEndSystemGroup"
Content-Length: 534
code:
Distributed_IPS 192.168.10.78 CK infected true true
code:
HTTP/1.1 200 OK
Expires: 0
Expires: 0
Cache-Control: no-cache, no-store, must-revalidate
X-Powered-By: JSP/2.3
Set-Cookie: JSESSIONID=i8_RbyDv3bVVInElOP9AGNfyU3ygMHXVgIWB208A.extrememanagement; path=/
Server: ExtremeManagementCenter
Pragma: no-cache
Pragma: no-cache
Date: Thu, 20 Jul 2017 13:10:28 GMT
Connection: keep-alive
Server-Version: 8.0.0
Content-Type: text/html;charset=ISO-8859-1
Content-Length: 11663
code:
var aboutWindow = window.open ( url, "About", "top=" + cornerY + ",left=" + cornerX +&nbs
var newWindow = window.open ( url, title, "top=" + cornerY + ",left=" + cornerX + ",
background-image: -webkit-gradient(linear, left bottom, left top, color-stop(0, #3F3F3F), color
background-image: -moz-linear-gradient(center bottom, #3F3F3F 0%, #383838 50%, #434343 51%,&nbs
filter: progid:DXImageTransform.Microsoft.gradient( startColorstr='#3f3f3f', endColorstr='#555555',GradientType=0 )
/* We use the inset of the box shadow to create a subtle inner gl
S
http://www.extremenetworks.com/support/' target='_blank' title="Go T... /> lt;/body>lt;/div>
