How to Configure Netsight Dashboard ?
Silva1
Hello guys !
I just recently started with netsight , and i have seen some very com display with graphics , dashboards , showing features from the switches performances , here att office we have a big screen and i would love to be able to activate those graphics in netsight , i can see under the reports tab that i can choose dashboard , but they all show blank with no information !
What do i have to do to aktivate this ?
Txh for your time in advance !
5 REPLIES 5
Ronald_Dvorak
Honored Contributor
We should might start with the software version that you've installed and which license is enabled.
Bob_Maheu
Hello,
You can following the information in the following KCS article to collect stats for OneView/Extreme Management Center. The dashboards should then populate after a short time:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-setup-interface-and-device-statisti...
Bin
Hello Silva.
If you want to know how to add the device into Netsight though SNMPv3, you could reference the following link as the example.
http://enjoynetworkscommunication.blogspot.jp/2016/11/extremewireless-byod-lab-3.html
Jeremy_Gibbs
Contributor
Do you have any devices added into NetSight? I would suggest using only SNMPv3 for Extreme/Enterasys devices. Once you have devices added, you should be able to right click on the device from OneView and select "Collect performance data etc....".
