How to deploy FlexViews without a restart of Netsight ?
‎07-09-2014 07:15 AM
I've learned that I'd share my FlexViews with my other Netisght users by uploading the files to the
/usr/local/Enterasys_Networks/NetSight/appdata/System/FlexViews/My
FlexViews/
directory of Netsight.
The problem is that I'd need to restart Netsight to force the update to every client.
Is there a other way to deploy it without a restart as a reboot of Netsight isn't very practical.
Netsight version 6.1.0.121 early build
Thanks,
Ron
FlexViews/
Thanks,
Ron
6 REPLIES 6
‎09-30-2015 07:03 PM
Are saying to send the flexview to the other people you want to be able to use the flexview? The mibs are on the NetSight server, so anyone could access those.... Correct?
We are running 6.3.0.162.
Any other thoughts?
Any other thoughts?
Hi, I saw this behavior in version 6.2 with mibs from mymibs directory. I was not able to replicate this with 6.3.0.162 It seems to me as fixed bug. It works in 6.3.0.162 in my case. Z.
Regards
Zdeněk Pala
That is an interesting work around if restarting the server is an issue. My issue is that the FlexView displays but the fields do not populate. Any ideas?
The mibs were loaded onto the server and the server was restarted. Anyone is able to to see the data through console but noone is able to see through OneView.
Thanks
Thanks
