How to deploy FlexViews without a restart of Netsight ?
‎07-09-2014 07:15 AM
I've learned that I'd share my FlexViews with my other Netisght users by uploading the files to the
/usr/local/Enterasys_Networks/NetSight/appdata/System/FlexViews/My
FlexViews/
directory of Netsight.
The problem is that I'd need to restart Netsight to force the update to every client.
Is there a other way to deploy it without a restart as a reboot of Netsight isn't very practical.
Netsight version 6.1.0.121 early build
Thanks,
Ron
FlexViews/
Thanks,
Ron
6 REPLIES 6
‎09-30-2015 07:03 PM
Correct. You can put the flexview on client and restart the client. Then you can use it in console. If you want to use the flexview in OneView, then it needs to be on server.
Regards
Zdeněk Pala
‎07-14-2014 07:24 AM
You can upload the flexview and mib files to your client. Than you do not need NetSight server restart.
on my computer running windows = C:\Users\zpala\AppData\Roaming\NetSight\System\FlexViews
Regards
Zdeněk Pala
