How to get PowerSupply Serialnumbers of S-Series Switches via NetSight?
MartinS1
Hi there,
How can I get PowerSupply Serialnumbers of S-Series Switches via NetSight?
71K, 71G, C3 and K-Series is working 🙂
I'm using Extreme Management Console (aka NetSight) 7.0.6.27
Cheers,
Martin
3 REPLIES 3
Rich_Upshaw
New Contributor II
Try Inventory Manager in NetSight Java Version. I did a 'show system hardware' and it didn't come up with any serials for the PS for the S4 there. K-series you should be able to get them.
Jeremy_Gibbs
Contributor
I don't believe there is a serial number associated with a power supply inside of an S-Series. There might be one on the label, but I don't think the PSU reports one to the chassis. I can't find it anyway.
One of our customers got a S6-Chassis with 4 PSUs. And we can get the SN of only one of them via the FlexView "Physical Entity List" as well as the Inventory Manager.
But this PSU looks a little bit different compared with the other three. 🙂
