how to learn tcl ?
‎09-26-2018 08:30 AM
CAn anyone advise me how to learn tcl ?
there are some manual to use?
10 REPLIES 10
‎09-26-2018 11:50 AM
In addition to the recommendations above, I'd suggest taking a look at the scripts available on our GitHub.
https://github.com/extremenetworks/ExtremeScripting/tree/master/EXOS
You can learn a lot by using the scripts there as examples.
‎09-26-2018 08:36 AM
Sorry for not preferred answer, but recommend to switch to Python. It is more powerful and available on EXOS and on Management also...
Regards
Zdeněk Pala
Hello Visconti,
one further hint. If you have a first overview to Python you can have a look to the example scripts on XMC (see in "Tasks->Scripts). There are some easy and some more complex scripts.
With these scripts you will see how python works with XMC and the switches.
Here is a KB article with more infos especially for XOS:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-use-Python-on-EXOS
Best regards
Stephan
Best regards
Stephan
Regards
Stephan
Hello Visconti,
for the first steps it is useful to have look for general courses in the web. There are a lot of different websites.
Here is a good point to start:
https://wiki.python.org/moin/BeginnersGuide/NonProgrammers
and here:
https://www.tutorialspoint.com/python/python_sending_email.htm
Best regards
Stephan
and here:
Best regards
Stephan
Regards
Stephan
ok so where can I find manuals of Python ?
