How to Upgrade Third Party Switches Via Netsight
‎04-17-2018 06:40 PM
Hi Community,
Is it possible to upgrade third party switch firmware through Netsight?
How we can do that?
Thanks in advance!
How we can do that?
Thanks in advance!
4 REPLIES 4
‎04-17-2018 07:02 PM
Hi.
the answer is Yes 🙂
The exact procedure does depend on the Extreme Management Center (XMC) / Netsight version. In the latest version we added some more options to configure that.
In general here are steps:
1. upload the firmware file to your XMC to proper directory
2. configure XMC Profile including CLI credentials
3. configure assign the XMC profile to your 3rd party device
4. assign the firmware transfer method to the 3rd party device
5. run the firmware upgrade
What version of XMC / NetSight do you use?
Z.
the answer is Yes 🙂
Z.
Regards
Zdeněk Pala
Thanks Bin, very helpful!
Best regards.
Best regards.
Hi Alex,
If you are using 6.3, maybe you need to use Inventory Manager.
The following article maybe could help you.
https://gtacknowledge.extremenetworks.com/articles/Solution/Inventory-Manager-Pre-and-Post-scripts
Best regards,
Best regards,
Hi Z.
Thanks for your help!
Currently, we are using Netsight 6.3. Any limitations at this version?
Best Regards!
Best Regards!
