Netsight 8.1 Operation Log File
Hello, Does anyone know where the log for the Netsight v8.1 operations are stored? I need the log if the trap receiver was registered or unregistered at a switch. Thanks for your help Alexander
Does Extreme Management Center, XMC, have the capability of the legacy Solar Winds - Switch Port Mapper? I have looked through the FlexView and reports tabs and I have been unable to find them. The network equipment enrolled in XMC within my example...
Hi, I have some python scripts running in the XMC for configuration. Now I want to create some scripts for the governance. Can anyone show me a simple example, so I can know what the XMC is expecting as return from the script. Thanks, Jose Chaves
I have a number of Meraki remote office devices that need 802.1x authentication for wireless. Is there a way to enter a range of IP's for authentication. I believe the Extreme Control Gateways only allow discovered devices to be added as RADIUS cli...
Hi,When creating AAA LDAP configuration in control the requirements for the account needed are detailed here:https://extremeportal.force.com/ExtrArticleDetail?an=000090980I have a couple of circumstances where EAP-TLS is being deployed and the use of...
| User | Count |
| 102 | |
| 101 | |
| 44 | |
| 19 | |
| 17 |
