How to use Netsight to backup Extreme switch configurations?
Dineshkumar_Ram
Am using Netsight to backup the Extreme switch configuration. I have 100 switches in my network. Kindly help me with the steps to backup from netsight.
10 REPLIES 10
Dineshkumar_Ram
Thanks to Drew and Ronald.
Everything is good now after doing the below steps.
1. Open Inventory Manager.
2. Highlight the switch and then change to the Image Information tab on the right.
3. Select the original ExtremeXOS TFTP script from the MIBs and Script Overrides section.
4. Click the View button.
5. Copy the script and paste it into a new text file.
6. Change the name and description at the top of the script.
7. Change the@receive 5 to@receive 15 in the configuration archive section
8. Save it to the NetSight server in /NetSight_Instal_path/NetSight/appdata/InventoryMgr/properties/devicefiles
9. Select this new script for the Configuration MIB section of the MIB and Script Overrides.
10. Click the Save button in the upper right.
Drew_C
Valued Contributor III
Great! Glad Ron and I were able to help!
Thanks for sharing the steps you took to resolve it.
Ronald_Dvorak
Honored Contributor
The setup looks exactly like mine and I have no problem to backup my X440.
I'd upgrade to version 7 if that is possible.
Dineshkumar_Ram
341f2959c35d42c0930eccfa1100728c_RackMultipart20160722-28338-1yofyha-image_information_inline.jpg
- 6.3.0.179 version
- yes it is the IP of the netsight server and inside the netsight server am running TFTP server too. so that is the IP of both netsight and TFTP.
