How to use the Netsight to sending alarm when port without inline-power supply?
‎01-18-2016 06:18 AM
The Extreme switch X440 PoE fail always without error log.
When the PoE fail, CLI "show inline-power info" will return timeout.
Can I using the Netsight to notice me that the inline-power is fail?
And how to create the alarm when the port without inline-power supply?
10 REPLIES 10
‎01-20-2016 04:49 AM
I have found that the error message "Erro:HAL.Card.Error".
And how to use the syslog to trigger netsight sending the email?
‎01-19-2016 02:48 PM
The PoE failures (Hardware and EXOS version) are similar to article:
Switch loses Power Over Ethernet until next rebooted
The recommendation is to contact GTAC for further investigation.
‎01-19-2016 03:49 AM
Hi Chan,
Could you please check if you see any messages in the log like below:
06/26/2014 20:41:01.16 Slot-1: poePlusInit: Initialization failed Slot-1 DESWMUELEO13-OG4.2 # show inline-p sl 1 Timeout occured while retrieving information from hardware.Usually, we will have the poe plus init failure in the logs. May be this could be sent to the syslog server.
‎01-19-2016 12:14 AM
The X440 version is 16.1.2.14.
There is no PoE error log. So Netsight can't receive the error.
‎01-18-2016 02:59 PM
Which EXOS version is running on the switch?
