[email protected]:/usr/local/Extreme_Networks/NetSight/appdata/logs$ tail -f tam.log
351147 1456293600020 Configuration.5.Event NetSightServer co1p130mo.falabella.com --- Default Secret Value The default password should be changed for the Web Service Credentials in Appliance Settings: Default
351148 1456293600020 Configuration.5.Event NetSightServer co1p130mo.falabella.com --- Default Secret Value The default shared secret should be changed for the Switch Configuration in Appliance Settings: Default
351149 1456293600021 Configuration.5.Event NetSightServer co1p130mo.falabella.com --- Default Secret Value The default password should be changed for the Admin user in Local Password Repository: Default
351150 1456293600022 Configuration.5.Event NetSightServer co1p130mo.falabella.com --- Default Secret Value The default password should be changed for the Sponsor user in Local Password Repository: Default
351307 1456297200005 End-System.6.Event NetSightServer co1p130mo.falabella.com --- Remove End-Systems and Events End-System cleanup started
351308 1456297200007 End-System.6.Event NetSightServer co1p130mo.falabella.com --- Remove End-Systems and Events End-System cleanup complete
351309 1456297200008 Health Result Aging Event.6.Event NetSightServer co1p130mo.falabella.com --- Health result aging Complete No health results to remove
351310 1456297200008 End-System.6.Event NetSightServer co1p130mo.falabella.com --- Remove End-Systems and Events Transient End-System cleanup started
351311 1456297200009 End-System.6.Event NetSightServer co1p130mo.falabella.com --- Remove End-Systems and Events Transient End-System cleanup complete
352272 1456320671752 NAC Web Update.3.Event NetSightServer co1p130mo.falabella.com --- NAC Web Update Check An error occurred while trying to contact
www.extremenetworks.com for assessment software updates. Check to see if the NAC Assessment web update server and proxy settings in Suite Options are correct. HTTP Response Error Details: java.net.UnknownHostException:
www.extremenetworks.com.
