Install problems with Netsight OVA (Ubuntu based)
‎07-31-2015 08:23 AM
Hi guys (well maybe a few girls too),
I have the following problem: I try to migrate from NetSight WIN based to NetSight Linux based so I downloaded the Ubuntu OVA file including Netsight.
I put it on my ESX, startet the console and did the initial Installation and put all the info in it. Ubuntu/Netsight told me everything ist completed and I can start using it. But unfortunately I am not able to connect to the Netsight webgui/user interface. I checked the VM again and when I run the 'nmap localhost' command I can see no service running on 8080 or 8443. I started the startserver.sh, no change. I rebootet the whole system...no change. What's my mistake? Why ist teh Netsightserver not starting?
Thanks a lot in advance.
11 REPLIES 11
‎08-19-2015 04:56 AM
Well solved is not the correct term, the initial problem with 6.2 is still up to date, even after downloading and installing it again. SO at the moment I changed to 6.1 and everything is fine. In a next step I wil update 6.1 to 6.2 and will see if the problem pops up again or not. If not I can live with that.
‎08-18-2015 03:54 PM
Hi Stefan, I just wanted to check in to see if you were able to get this resolved.
‎08-03-2015 09:58 AM
Stefan, I would gather the 'show support' from the setups and open a case with the GTAC.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-generate-a-show-support-from-Onevie...
‎08-03-2015 06:19 AM
Funny thing. I accidentely rebooted the VM two times a row, now it is working. Well at least the 6.1. tried the same with the 6.2 but no luck with this one. Now I am a little afraid I will lose connection again on the 6.1 as I have no clue what the problem was.
