Management Center Installation Requirements
Paul
New Contributor III
When reading the Management Center installation guide it mentions the server requirements for small, large and enterprise installations. I assume this is referring to the number of devices being managed but there is no indication of the limitation of each installation. Can anyone shed some light on this?
Also, are different licenses required for each of these levels?
7 REPLIES 7
Bharathiraja__S
Hi Paul,
I guess to get better answer on this part we have to check with Deployment team,
Thanks,
Suresh.B
Paul
New Contributor III
The customer currently have around 90 nodes consisting of Summit switches some of which are stacks of 2 or more members. Would this be covered by the Small deployment?
They currently use Netsight and I believe this runs on a Windows Server.
Bharathiraja__S
Hi Paul,
May I know what kind of limitationā€™s that you are looking for in specific,
I can see below details from release notes.(page no#7)
Extreme Management Center Server
Small Medium Enterprise Large Enterprise
Total CPUs 1 2 2 2
Total CPU Cores 8 16 16 16
Memory 16 GB 32 GB 64 GB 64 GB
Disk Size 240 GB 480 GB 960 GB 1.92 TB
IOPS 200 200 10,000 10,000
Recommended scale based on server configuration:
Maximum APs 250 2,500 25,000 25,000
Maximum Wireless MUs 2,500 25,000 100,000 100,000
Maximum Managed Devices 100 1,000 10,000 10,000
Access Control End-Systems N/A 50,000 200,000 200,000
Statistics Retention (Days) 90 180 180 360
Application Analytics No Yes Yes Yes
MU Events No Yes Yes Yes
Thanks,
Suresh.B
