Hi Jason,
Thanks for replying. I haven't tried this config using the default Netsight syslog pattern, but when I do I'll report back if it works ok.
The question I have is around setting the severity to 'Debug-Data', as the configuration guide states the following:
The three severity levels for extended debugging—Debug-Summary, Debug-Verbose, and Debug-Data—require that log debug mode be enabled (which may cause a performance degradation).
So just checking its safe to use the debug-data severity with debug mode enabled on all switchs?
You might just have given that as an example. Currently I have it set to Info, so that is probably sufficient.
Many thanks
