Mixed legacy Enterasys S/K/N/C and Extreme Syslogging in Netsight
Anonymous
Not applicable
Is there a way to officially configure syslogging for both legacy Enterasys hardware S/K/N/C and Extreme switchs.
Currently the Extreme syslogging works if I change the syslog pattern to 'Red Hat Linux Syslog'
Enterasys syslogging works if I change the syslog pattern to 'Netsight Syslog Pattern'.
Each switch has various firmware versions, to list a few:
12.4.2.17
08.02.01.0012
06.71.05.0008
15.1.1.6
7.6.e3
11.5.2.10
Netsight is running version 6.1.0.171.
Suspect the configuration maybe in the format SNMP configuration in EXOS, that is currently configured on the Extreme switchs as so:
timestamp seconds date Mmm-dd event-name none process-slot priority tag-name.
Many thanks.
5 REPLIES 5
Jason_Parker
Contributor
If you want to set commands on the each switch model you could set these commands through the execute command script tool in Netsight to ssh or telnet to the switches and execute the proper commands If you are concerned with setting the server commands I unfortunately cannot help you
