My Syslog I keep receiving an error from my NetAtlas stating: bootpd: stat on "bootptab"
Fritz_Trappey
In my Syslog I keep receiving an error from my NetAtlas stating: bootpd: stat on "bootptab". No such file or directory I'm not sure what this and can't seem to find anything in the settings reflecting something even close to it, so I'm either looking this up in the wrong location or it's nothing to worrry about. I'm getting an error every few minutes. Any ideas?
9 REPLIES 9
Anonymous
Not applicable
Annelise,
You need to disable the bootpd process on the Netsight server. This process is listening on Bootp/DHCP ports and is what's triggering the messages being displayed.
Once the bootpd process has been disabled, the messages should no longer be displayed.
Chris
Annelise
I have the same problem as the colleague wrote. How do I disable these messages being generated?
Tamera_Rousseau
Hi Fritz, did Chris resolve your issue? If no, perhaps you can give us a little more information about your configuration? Thank you!
Anonymous
Not applicable
Fritz,
I'm making an assumption that the version of Netsight you have installed is on a windows system. By default a windows install of Netsight includes a TFTPD, SNMPTrapD, Syslogd and a bootpd application.
A typical install will not only install all of these side apps, but also enable them.
Bootp port number is the same used for DHCP, so you are likely seeing local DHCP requests on the network (because they are broadcast) hit the bootpd process. We don't actually do anything with them....but they are listed in the syslog tab. Easiest way to correct this issue would be to disable the bootpd process on the Netsight server. (again assuming this is windows) If you are on the server itself, there is a services icon in the system tray. From there you can disable the bootpd process. This should help you determine if this is indeed your issue.
If this does correct the issue, I think you need to go into Netsight, tools, options, there should be a place to uncheck bootpd as normally it will start up every time you restart the server.
Chris
Another option is to go to your services filter under the Administrator Tools folder and select Netsight BootP Service and then select startup type and change tpo disable
Jason
