NAC Appliance Web-Session timeout
Chacko
Contributor
is there a configuration option to change the default-timeout for the Web-session?
I'm connected to the Webserver of the NAC-Appliance (IP:8443/Admin), but the session is closing after ~5 minutes - very annoying.
Best Regards
Chacko
4 REPLIES 4
Ronald_Dvorak
Honored Contributor
BTW, for what do you use the portal - I'm curious because I never use it and wonder whether I miss out on something 
StephanH
Valued Contributor III
Hello Chacko,
it would be nice to change the session timeout! But maybe the following workaround can help you:
You can reach the NAC server.log via NAC Manager (the Java tool) with a right click on you appliance and selecting "NAC Appliance Log..."
Or you use a SSH session to your NAC Appliance and browse your logs (there are several) in /var/log/ and /usr/local/Extreme_Networks/NetSight/appdata/logs
Regards Stephan
Yes, exactly the same over here (troubleshooting).
If you got the logs in the NAC-Appliance Web-GUI and want to compare them, e.g. with radius-logs of a different and with every refresh you have to login again, it's a little bit annoying.
Ronald_Dvorak
Honored Contributor
I don't think that you'd change it in the GUI, at least I can't find a way to do it.
Might be that someone from engineering could tell whether the parameter could be changed in some kind of config file on the NAC appliance.
-Ron
