08-01-2016 02:12 PM
08-01-2016 05:58 PM
08-01-2016 05:43 PM
Enter search criteria to filter table. One or more filters may be entered, separated by semi-colons. For each filter, individual components of that filter are comma separated. Specific flow components must be specified with a key. Keys are not case sensitive.Does anyone know if this filter syntax can be used in the Administration > Options > NetFlow Collection > Advanced > Flow Collector Filter field?
Supported keys: CLIENT, SERVER, SERVERPORT, PROTO, SENSOR, IF, INIF, OUTIF, APP, APPGROUP, META, LOCATION, DEVFAMILY, USER, PROFILE
*Note: CLIENT/SERVER may be an IP (CIDR Mask Supported) or host, and may contain a port (X.X.X.X:P)
Supported modifiers: duration, size, packets, bps, with a comparator of: >, >=, =, <, or <=
Supported keywords: Include/Exclude (Include is implied)
Fuzzy filters and partial hostnames are supported
*ie "Doe" will return flows w/ hostnames "JonDoe", "JillDoe", etc
Additionally flow metadata can be searched by using a colon as the key-value delimiter.
Example: meta=Content-Type:application/json
Everything is case insensitive.
A Fuzzy filter is a string without a keyword. It can partially match any value in any column. E.g. "Google" would match source or destination host name "www.google.com";, or application names "Google Mail" or "Google News".
Examples (single filter):
1) "client=JonDoe, server=10.20.77.33, snmp" –> SNMP Flows from host JonDoe to 10.20.77.33
2) "JonDoe, SENSOR=10.20.77.33, snmp" –> SNMP Flows from netflow sensor 10.20.77.33 To/From JonDoe
3) "SERVERPORT=161, duration>1000, exclude" –> All flows EXCEPT SNMP(161) flows that lasted more than 1 second
4) "snmp" –> All snmp traffic
5) "10.20.77.33:161" –> flows where server/serverport = 10.20.77.33:161
6) "JonDoe:161" –> snmp flows to or from JonDoe
7) app=DNS –> All flows identified as belonging to the application "DNS"
app=89 –> All flows identified as belonging to the application whose ID is 89
9) appgroup=Social Networking –> All flows identified as belonging to the application group "Social Networking"
10) user=none,exclude –> All flows with an identified user
11) inif=11002 –> All flows where input interface = 11002
12) meta=snmp–> All flows with metadata containing the text SNMP
13) meta=Content-Type:application/json;> All flows with an application type of JSON
Example (multi filter):
1) "SERVERPORT=161, duration>1000, exclude; CLIENT=JonDoe; CLIENT=JillDoe" –> All flows from JonDoe and JillDoe except SNMP flows lasting more than 1 sec
If the filter fails to find a match, no data is displayed
08-01-2016 04:17 PM
08-01-2016 04:17 PM
08-01-2016 03:05 PM
