Netsight 5.1 and Java
Carl1
What is the current supported version of Java for Netsight 5.1?
4 REPLIES 4
Alexander_Duske
ok, thanks, thats good to know. But we'Re still using Netsight 5.1. Anyone got some info about java 8 and Netsight 5.1? šŸ™‚
Ronald_Dvorak
Honored Contributor
I've the latest Netsight 6.1.0.171 installed and use Java 8 build 31 without any issues....
Alexander_Duske
Hello,
is Java 8 supported by version 5.1?
And wat is the latest supported Java Version for the most recent Netsight Version (does it even use Java any more?)?
Paul_Poyant
New Contributor III
I consulted with my NetSight support colleagues.
NetSight 5.1 supports up to the latest Java release (the latest available at www.java.com is Version 7 Update 55). Due to issues seen with some earlier versions, on general principle you should run Version 7 Update 51 at a minimum.
