NetSight 6 OneView Search / Portview does not work
Michael_Kirchne
Contributor
In a new NetSight scenraio which is installed with NetSight 6 several OneView functions does not work as expected.
This includes:
- The Search does not work (e.g. if a Device from NAC is searched)
- Portview does not work (Wireless Solution 8.32.05.0007)
Any ideas? I also see that even if Oneview device collection is enabled for the wireless controllers - no APs or Clients are seen.
I hope you can help me.
PS: New Guest Registration Portal looks fine šŸ™‚
Best Regards
Michael
8 REPLIES 8
Zdeněk_Pala
- The OneView search (in version 5) has new feature that try to translate the searched criteria through DNS.
- I saw this issue when it was running on Demokit and the DNS was "answering for every request" can this be your issue? what does the DNS (/etc/hosts) answer for your search?
- You can try disable the name resolution in Console -> Tools -> options
- You can try enable debug for search.
Regards Zdeněk Pala
Michael_Kirchne
Contributor
Both yes but indeed I had a mistake in the cli profile. But thats adresses only the wireless issue or also the search Problem?
Best Regards
Zdeněk_Pala
do you gather oneview statistics?
rightclick on the controler (console or devices) -> oneview -> collect historical statistics
Do you have CLI credentials configured in access profile?
Regards Zdeněk Pala
Michael_Kirchne
Contributor
NetSight is 6.0.0.78
